- Joined
- Nov 14, 2010
- Messages
- 28,552
- Reaction score
- 28,404
Good info on here for those shopping for a new carb. Gotta love these forums!
Rochester made a Quadrajet as a Thermoquad replacement in the early 1980's. I have a Quadrajet I will try on my 383 someday, plus a Thermoquad, and Holley Economaster. Currently, I have a Holley Pro-jection 670 cfm TBI (since 1996). It is a bit quirky, but better than the original Rochester 2 bbl. My final solution will probably be a Holley Commander 950 TBI. Before trying above, I want to install a Offy Dual Port intake for better mileage and driveability, but my A-bodies are keeping me occupied.I wonder if you can mount a Quadrajet on a 383?
your engine guy is correct. eddies are cheap. they look nice but thats about it. run a proform if you can afford it . they are in my opinion the best carb on the market . basically a holley with balls.
After years and years and years of always of always trying to make things better by swapping Holleys, Eddys, modified carters, etc, on and off like diaper on a baby, I recently tried something different. I sent my T-Quad smogger out to a guy who restores them to 100% factory spec and flow tests them before sending it back.
I popped it on and after doing some simple primary jet enrichment adjustments to compensate for my removing mot of the smog crap, it runs like it just came out of the dealership.
A lot of times one can't be smarter than the factory engineers.
I have 2 T-quads in my possession right now in my parts cabinet. Big ol' ugly things but they are in good enough shape to be rebuilt...don't know the cfm ratings on them tho. I always heard to stay away from those due to the "phenolic resin" main body....it warps in shape over time b/c of the heat(?) Old wives tale, then? I dunno sounds like its no problem for you.
I had a T-quad on a 73 Challenger with a 340. That phelonic center section warped and leaked gas and was replaced under warranty twice. I could smell gas in the car it leaked that bad. Ended up putting an eddie manifold and holley carb on her. No more leaks.
Many did. Most of them didn't.I always heard to stay away from those due to the "phenolic resin" main body....it warps in shape over time b/c of the heat(?) Old wives tale, then? I dunno sounds like its no problem for you.
Commando1. said:Many did. Most of them didn't.
When someone can't get their engine to run smooth, they first thing they hear from the know-it-alls is: "it's those damn plastic thermoquads. They all...."
Personally, I find them overwhelmingly complex but there also was a time I found a tieing my shoelaces overly complex...
For less that the price of a new aftermarket carb, I got an as-new carb designed for my engine and it was practically plug 'n play out of the box. Every other person swears by Scott Smith's T-Q's.
By the way Demon Sizzler is now out of business for those that knew who he was.
If I was building a hi-po engine, then I'd definitely go aftermarket. I'm out of the RoadRunner chasing game now.
Ditto commando1. Many people on forabodiesonly adore the Thermoquad. The problem is getting a good one and parts are getting rare. That is the carburetor I would use, if I wasn't using EFI. Nothing else has such tiny primary bores and monster secondaries. I do have a TQ to play with, just because I think carbs are neat and I used to design aircraft fuel controls at Bendix.
The Quadrajet is the closest equivalent. It also has people that swear by it and others that swear at it. When new, it was probably the most efficient 4-barrel carb made that still had power. Mostly used on GM cars, but factory on some Mopar's in the early 80's.
Well, guys maybe I should think about going with the t-quad, don't know if they will mate with the performer intake although they are spread bore carbs. Plus like commando said, parts are scare. I assume the T-quad having tiny primaries (they are rather small now that I look at it) and huge secondaries equates to decent gas mileage around town, and rocket launches when ya put your foot into it?
Did T-quads come stock on any 383's?
Never.Did T-quads come stock on any 383's?
