thethee
I don't understand what's happening.
Drove the car to an empty lot (~10 minutes) so I could make my adjustments. Parked with running engine to check vacuum at vacuum advance line, but before I could attach the gauge engine died without warning. Attached the gauge to the carb and went for hot start. Started with just a touching the key.
Idled nice, vacuum advance line had NO vacuum at idle. Raised rpm to check and then it did have some vacuum. Then without warning it died again...
Attached my multimeter to the coil for next time it dies to see if coil loses power. It didn't, it idled smooth for about 20 minutes, all the while coil had steady 8.8 V.
Turned off the engine and by now it should be proper "hot" start. Started with just a flick of the switch.
Final check, reattach vacuum line to distributor, single crank and it started.
Going to back down initial to 16 degrees and call it a day.
