http://www.mustangandfords.com/how-to/interior-electrical/vintage-ford-mustang-clocks-repair-fixLet me dig for it... I bought a kit and installed it myself. It was easy.
Poor connection on that circuit.The high beam indicator stays lit
Thank you for theses initial thoughts.
I just fixed my speedo on my 66 Polara. I was nervous to mess it up, so when I was at Chryslers at Carlisle, I bought a backup for $25. I cleaned all the old grease and funk out of the gears and relubricated it. There’s a Brass cap on the top of the speedo that can be removed with a small screw driver and then remove the little piece of felt that’s in the hole. I used plenty of lubricant spray.
There’s a YouTube video showing the felt and lubricating. It’s from an old Pontiac, but to my surprise, the insides of the speedo are very similar. below is the link
At 6’7”, I have realized it takes a special kind of yoga to work on the dash.
On the speedo, if the issue is not at the trans pinion or the cable itself, is there a place that rebuilds the mechanism in the cluster? Is this something easily done at home??
bulbs should be here by the end of the week!
Contact this guy...Anyone out there know the nut I need to fit the odometer reset cable poking through the bottom of the dash on my ‘68 300? It apparently fell off years ago, but I never knew because the speedometer/odometer never worked.
I cannot find a proper fit at the hardware store.
Thx.
Good progress!Doing the last bits of the ammeter and under hood bypass.... I found the NOS fusible links on eBay for about $2 plus shipping. I like how they have the rubber ‘FUSIBLE LINK’ embossed on the tag. Looks cooler than what I wa finding at the local auto parts store and a little closer to the original.
got em installed and fired her up. Good times.
I used Instrument Specials. They did an awesome job. But, $$$$$.
Success!
Might be hard to see, but in the second pic you can see the Blue glow of the new bulbs. Thought at first it was a total failure... but theN realized the dimmer was all the way down.
Bulkhead and under hood bypasses next.
