What did you do regarding the clock?
I boxed up the clock for now and installed the Clock delete plate in its place.
Congratulations!Got her out for a test drive this morning before it gets to hot. Speedo working well. About 12% off compared to the iPhone app, but I can live with that.
The gas gauge does move, but only very slowly and only up to the 1/4 tank line before moving back down past Empty.
going to take her back out after dusk to see the panel glow.
thank you for all the guidance and encouragement on this project (especially @cbarge ). I learned a lot and gained some electrical system confidence along the way. View attachment 392001
Congratulations!
I am ignorant of the Mopars, but Fords have a series of speedometer drive gears that were used (for various rear end ratios - I used them for that and in changing to 225-60-15 tires). I bought several of the drive gears and did mile marker tests to get the speedometer on my Mustang to within 2.5% (it reads high).
What size tires and rear diff gear ratio?About 12% off compared to the iPhone app,
A member here has a thread regarding calibrating the gauge..The gas gauge does move, but only very slowly and only up to the 1/4 tank line before moving back down past Empty.
P255/75R/15 on the tires. How would I figure out the gear ratio?
The fender tag will have a number under the AX prefix.
1 is 2.76
2 is 2.94
4 is 3.23.
There should be a tag attached to one of the nuts on thw rear diff with gear ratio on it toi.
Question is..is there a 26 tooth in the trans? HHmm
Switching gears (pun intended), anyone here have experience with the solid state voltage limiter on the back of the panel? I got mine from Vans Auto... beginning to wonder it by chance that could be the source of the fuel gauge issue?? There is a tiny little Phillips screw on the back. After reading the post on the Meter Match, I am begging to wonder if that is an adjustment screw of some type (not that I want to pull the panel apart again to get to it).
