If you are doubtful of your ignition 12 volt supply I highly recommend a dedicated ignition relay to offload the ignition switch contacts. This is a very inexpensive upgrade and very easy to do. If you end up rebuilding the carb, the best kitt comes from Rock Auto. Do not, under any circumstances trust the cardboard float gauge that comes with the kit. It'll get you in the ballpark but it's not ideal. These carbs are sensitive to float levels and "trial and error" by removing the top of the air horn to reveal the exact fuel level in the bowl is the best way. I installed an MSD distributor once that required the gear to be removed and a brass gear installed. The information to do this came from the cam manufacturer and it can go the other way to. Has to do with premature wear or self destruction.
