patrick66
A 400 is nothing but a 383 with bigger bore holes. Plus, the 400 was a smog engine from the beginning, designed to work with the then-new emissions standards. As stated, the early 400s are more desireable than the early ones, because of perceived thinner cylinder walls - that has been disproven, along with the same alleged "weakness" in the '74 - '78 440 engines. You can build the 400 exactly the same way as you would any 383. Use earlier 383/440 factory exhaust manifolds, a Carter AFB or a T-Quad, a cam installed correctly and the timing set accordingly...you'll have a 400 every bit as capable as a 383 4-barrel from the factory. Plus, someone looking at the engine at a car show will NEVER know the difference.
