Well . . . I guess our (my family's) experiences and y'alls are very different. I never saw a rear wheel bearing being lubed at the local dealership. Also, we've never had that done to any of our C-body cars, all of which have over 150K on them. The '66 had a noisy bearing when it had about 45K on it, so it was replaced, but no mention of it needing greasing. Never saw it happen in any private shops either. Our cars saw "normal" use. IF I'd seen that being done, back then, I would have been asking questions -- period.
I looked in the '66 and '70 C-body manuals and noted that it said, upon installation, to grease the bearings with NLGI #2 (chassis grease) upon installation. Neither maintenance schedule listed anything other than rear axle fluid changes or level checks. With non-HD use, just a check every so often. With HD use, change intervals were about 24K, but no mention of re-lubing the rear axle bearings.
I saw both seals, one at the outer flange metal stamping and the one farther in on the axle shaft. It appeared that the inner seal's diameter would allow axle lube past it as it was smaller in diameter than the outer diameter of the bearing assy.
So, the way I read the manual, the chassis grease in the bearing is more like "assembly lube" and the axle grease then, with time and lateral body motion, washes it out and replaces it for the long term.
So, I guess I need to do some more research on this subject?
Respectfully,
Respectfully,
