In the early OEM efi days, we had customers who put 100 gallon L-tank aux fuel tanks on their pickups for long distance trailer pulling (think horse trailers, cross-country). With their normal pumps, pre-efi, no problems. With EFI, could not do. Tried the biggest Holley race pumps and still no workie. That was the first time we realized that EFI took PRESSURE and VOLUME at the same time! We ended up having to get the little inline EFI pumps at about $100USD in the later 1980s. YIKES, but they worked. An area aux fuel tank manufacturer had them.
It's ONE thing to mount the reservoir/sump/pump combination on the core support by the horn as the normal pump supplies it. Then the internal high-pressure pump takes over and feeds the EFI unit. BUT to have an EFI pump mounted at that level also means "no head" (as in fuel normally at that level), so harder to pull fuel it was not really designed to pull. One reason the electric fuel pumps are always mounted much lower in the body! They get natural fuel feed.
The OTHER thing is that with that higher mounting level, it can make the integrity of the fuel line behind the pump much more critical. ALL of the fuel line sections, not just the ones visibly seen. Especially with ethanol'd fuels.
In the later 1990s, we started to experience normal wear-out of OEM EFI in-tank pump modules. The defining symptom was "extended crank time". With a fuel pressure gauge installed, the engien would crank normally until the fuel pressure hit the magic min-pressure number of about 56psi. Just as the needle touched that number, the engine fired and ran. The old manual RoosaMaster diesel injection pumps were the same way.
