John Kirby
I'm new to this forum so I will give a little background.
I rebuilt the 440 in my 66 nyer 2dr HT back around 2000. Put in 10.5:1 keith black pistons, balanced and blueprinted the engine while it was in the machine shop. Figured I'm doing it once, better do it right. Installed a crower beast cam at the time too. Ran it for a few hours to break it in. Due to a job change and other life issues it sat for many years. Finally started working on it again a few years ago. got the body work and painting done and now registered for the road.
A few weeks ago I was performing some upgrades in the engine compartment area, installed an aluminum water pump housing, some CVF racing billet brackets so I could upgrade the A/C to a sanden compressor. After all of this was done I ran the engine and everything seemed fine. Sh ut it off and a few days later started it again and a loud squealing noise started coming from the engine. I initially thought it was the water pump but removal of the belt did nothing to stop the noise. After about 10-15 minutes it quieted down but occasionally it would briefly reappear. I then changed out the oil pan for a chrome one from Summit and noticed some fine metal particles at the bottom of the pan. This seems very bad, so I pulled the top of the motor off and was checking the cam and it looks like somehow the cam has shifted backward towards the rear of the engine. The photo I hope makes it online here shows what it looks like from the passenger side of the car. You can clearly see the lifters are not centered on the lobes. It looks like the cam has shifted back towards the rear of the engine.
Anyone have any idea what keeps the cam centered in the engine? I looked in the parts manual but didn't see anything obvious that serves this function. I'm stumped at this point.
