- Joined
- Nov 14, 2010
- Messages
- 28,241
- Reaction score
- 27,595
Don’t wait too long to do the other side, there’s no sense in letting your body recover from this job without a hoist just to do it all over again....
Good to hear Gerald!FINAL UPDATE! Finished the job this afternoon. Took Tilly out and she drove straight and true right off. I'll use my AARP discount at an alignment shop sometime if I feel the need. I maxed the caster using stock upper control arm bushings, minimal toe in when I centered the tie rods and ECCE! I can let her toddle down these bumpy barrio streets and she finds her way with scarcely a nudge from me. Not too bad....
All I would do if she drives nice... is occasionally run my hand across the front tires and check tread depth inside vs outside... you'll see any alignment problems in the tire wear pretty fast if you keep track.FINAL UPDATE! Finished the job this afternoon. Took Tilly out and she drove straight and true right off. I'll use my AARP discount at an alignment shop sometime if I feel the need. I maxed the caster using stock upper control arm bushings, minimal toe in when I centered the tie rods and ECCE! I can let her toddle down these bumpy barrio streets and she finds her way with scarcely a nudge from me. Not too bad....
Beat you're glad that's over... I'm finding myself to be less and less excited about working on the ground.
