Mirror help please...
Cadee
Ontario, Canada
I bought a used passenger side mirror and was told it would fit my 70 Fury, got it home and of course, it is not correct so... can someone please tell me what it does fit?
Thank you
Left round chrome manual mirror 69-70.
Do you have a remote mirror on the driver's door, one that you move with a joystick on the door panel?
The door will have two small holes for the screen to hold it down, and a larger hole for the cables to route through.
You can always go to The 1970 Hamtramck Registry Home Page and dig through all the good stuff there, look at the 1970 Fury sales brochures, and you should see what mirrors were options for your car.
The mirror is definitely for the passenger side, it just doesn't look like the drivers side I have on the car, which I know is correct.
Also have 2935337 NOS Left manual mirror 1969-70 Fury 2935806 cast on
I had the cast number not part number, but it's still a driver's side mirror, as Marty concurs. Swivle the head to the other side and it should look correct.
There are two style mirrors. Remote and manual. That is the "companion" right mirror for a manual left.
Is your left mirror a manual or remote mirror?
This may help...
1970 Fury Side View Mirrors
Be aware of that Fuselages did not have remote controlled right outside mirrors.
While that is true that the mirror isn't remote controlled (cable, joystick etc.). It is a "companion" mirror to the left remote mirror in that it mimics the "hooded" style of the left remote mirror.
That is a non-remote mirror, it appears to be the style that might have been used in 1970.
The number is a casting number and not the part number.
There were 5 different non-remote mirrors for 1970 (full line, just left)
There were 2 different Fury mirrors that were different than the 2 mirrors used on the Chrysler/Dodge/Imperial.
So which mirror do you have? It is not as simple as right/left non-remote/remote.
Alan
Any of you guys used A or B body sports on your car. I never considered adding the RS chrome mirror but when I saw this it got me thinking...
I hope this helps. The mirror that you are looking for is 1969-1970 Plymouth Fury ONLY. Dodge and Chrysler had a different base angle.
These are the RH numbers to match a LH remote mirror
RH MoPar #2945608 , 2999124 . 2999002 base casting #
I hope this helps
Devin Duke
Folsom, CA
