WANTED Molding clips - '65 Fury - for bottom windshield molding strip that attaches to cowl cover
barsteel
Monroe, CT
Pic attached.
These are the clips for the bottom windshield molding that mounts on the cowl cover. Au-Ve-Co does NOT have them, nor was I able to find any on Ebay. Au-Ve-Co has similar clips, but they will NOT work.
The square portion of the clip is flatened so that it can fit into the molding channel.
I need 8 of them. Please msg me if you have them. Thanks...
Chris
Tony's Parts in Delaware is parting out a pair of 68 300,so the clips should be the same.
Also try National Moparts in Beaverton,Ontario,Canada. Nigel has a yard with a number of C's parts cars.
Finally try Murray Park.
I was surprised Au-Vee-co did not have them. I had good luck using their products in the past.
You can try Spaenaur in Canada they have all kinds of fasteners and tools. They helped me get clips for my car.
Thought I might have some but only have 1 which doesn’t do you much good.
I have 7 of them. They need cleaned up but were in the trim and a bit@# to get out so they should work.
20 bucks shipped to CT. I only take payments thru FB.
