Dsertdog
Last month I purchased a Mopar electronic ignition conversion package from a very reputable seller. It is NOT a proform kit.
I installed it according to the very good instructions and the car wouldn't fire.|
It would fire right back up when I reinstalled the points distributor.
On a whim I bought a spare box, had both ECUs tested and bother were good. The seller did his level best to try and help me, but even he is stumped, saying it's some kind of weird wiring problem. Other than the ammeter bypass and a tach, the wiring is stock
I can offer all kinds of voltages and such, but I have tested everything for continuity and every wire checks out.
Here's what is strange. With the points distributor installed and the engine running, I have 10.1 volts between the coil positive terminal and ground.
When I plug in the ECU and the electronic distributor, the best I can get is about 7.5 volts at those terminals. Usually, it's about 6 volts. Not enough to run car.
I finally managed to start the car, but it ran poorly...rich and dank exhaust and it set the CO monitor off in the furnace room. Voltage at coil+ to ground was almost 8 then dropped. Car still ran but wouldn't restart after shut off.
Put the points distributor back in and she pops right off.
Help? Please?
1966 Polara 383
Help? Please?
1966 Polara 383
