- Joined
- Nov 14, 2010
- Messages
- 28,569
- Reaction score
- 28,453
Do you have the fsm yet?
Not yet, it's on the list.Do you have the fsm yet?
Any Interior pictures Mr. C you can share with us?
I actually have spares of the 2 rods shown in the pic so if it turns out you need one or both you would have first crack at them.Not yet, it's on the list.
if you need parts I maybe able to help
Towing vehicle carries insurance period no matter what they say. Trailer has no operating controls, no operator, no lawyer anywhere will go into court and try to prove it was the trailers fault even in a mechanical, material failure. By lying to them you completely let them off the hook if you end up in court but they will not be standing next to you any how. Once you hook up to that trailer it is you liability on that unit.
Say what?am seriously looking into doing the 86-92Toyota Supra rotor conversion
All ball joints and control arm bushings are available straight through Rare Parts. I'll be interested in the thickness of your rotors as I think mine are getting thin.My initial plan with the convertible (I still can't believe I have a 68 Imperial convertible!) is to get it mechanically reliable for me to cruise around this summer.
It stopped raining yesterday and I was on leave, so I spent most of the day with the Imperial before the rain resumed. The L78-15 Good Year "Power Cushion" bias ply tires that came with the car started to let go up front, and I had a flat. Not wanting anyone in the community to complain about a derelict car, I had to get tires under it. I swapped a set of 205-75-R15 tires I had on a set of M Body rims onto the car to keep the neighbours appeased. Took 2 hours to break the beads and get the bias plys off, the rubber was so stiff!
While I was in there, I looked into the Budd discs as the pedal nearly goes to the floor before I get braking action but no brake light comes on. Previous owner replaced the master and booster and a few lines...haphazard approach IMO, but no leaks. Thankfully, the calipers are not leaking or sticking...I can spin to rotors by hand with the tires off.
The rotors look decent with no grooves(did not mic them yet) pads are just about toast (if they were of the riveted variety I would have grooves in the rotors...like 1/16 of an inch of material left- I think this may be why my pedal travel is extreme, but I haven't yanked the drums yet). Hoses are old but serviceable.
If my rotors are done, I am seriously looking into doing the 86-92Toyota Supra rotor conversion this summer since the cheapest rotors I've found were $189.00 each (I am glad they're available though). I found a place locally that will re-bond my pads for $85.00 as I have been unable to find D10 pads for less.
I have not owned a slab since the 90s (and that was a 68 Fury I) so I appreciate any advice on them. I heard that the Budd brake ball joints are another possibly tough item? Any 67- 68 Imperial expertise on tough items I should keep my eyes open for is appreciated.
No I'm talking about the trailer hitting another vehicle or property, cargo on the trailer needs to be covered by something else.Here in Michigan, my vehicle insurance covers the trailer only. Not the car, boat whatever i'm hauling on it. The boat or car need their own policy.
The 86-92 Supra rotors are dimensionally the same (except for hat height and hub centre hole) as the Budd rotor. To do the conversion the Imperial hub needs to be machined to make up the difference of the hat height and narrower so the Supra rotor will slide on (or the Supra rotor could be machined to a larger hole).Say what?
Tell us more. Never heard that one.
It seems to me that for as much as we drive these cars even at 5K miles a year it makes more sense to just do the rebuild on the original system and never worry about it again.
Out of pure curiosity, what did you have to pay for it?
