What are your plans for the motor for Delmae?
As of right now, its a nice looking table in the garage.
But current plans (since you also have a 383-2bbl):
- Full reseal of everything
- Ported 906 heads (possibly shaved) with 2.14/1.81 valves
- 1.6 roller rockers
- Edelbrock DP4B intake (might spend the money to have them port matched)
- 635 cfm Carter AVS from a 1971 383 HP car (#6125S but will be looking for a #4968S from a 440, which flows 750 cfm)
- HP manifolds
- Hopefully reuse stock bottom end and pistons but if not, probably .30 over with L2315 pistons (I want 9.5 to 1 compression MAX)
(Still need to buy the following):
- HP oil pump
- Comp Cams XE274H
- Electronic Igniton from Joe White and Rick Ehrenberg
- An air grabber intake would be nice
- Rebuild the original torque converter to match the cam or buy a neutral balance flex plate and torque converter
