Mystery connector on 75 Imperial with many wires.
Mbaird
Boise
I found this massive connector floating under dash pad when I was changing cluster bulbs. I can’t find it in my 76 FSM . My car is a 75 but most of the wiring should be similar.
There are some 16ga hot wires and grounds . Maybe for trailer towing ? Seems to be a lot of wires for that…
None of my warning buzzers work so at first I thought it might be for that but cant find a matching male connector . It comes from the drivers side cluster area and runs over to passenger side .
Headlight sentinel wiring
Looks to be it . Wiring must be unique to 74/75 Imperial. I am not finding any mention of it in my 76 Chrysler FSM . My car has the Sentinel system … where is the male connector ???
Hmmm. Will have to look once I have the cluster out . Pretty big terminal to hide .
Question still remains
“ where is the rest of the wiring ?” I will try to find a 75 FSM on line .
Fair enough
What I meant to say was, there is no more wiring after this connector.
Yes , I.understood what you were saying. I didnt occure to me that there was a module involved in the system until then .
I wonder if removing the module effected other things like dash lights or cornering lights ? None of which work now . I bought an NOS light switch with sentinel provisions thinking it was the switch effecting my dash lights
Cornering lights are not affected by this module and neither are the dash lights. Cornering lights are powered by fuse #8 and only go through turn signal switch. Dash lights are powered by fuse #1 and only go through headlight switch.
Best to check fuses and connectors
Dash lights are probably caused by a failed rheostat in the headlight switch. The dimmer part.
Picked up an NOS switch .
Hopefully this solves the dash light problem.
Cornering lights might be due to a rusted bulb and socket shorting out operation . Although the fuse seems to be intact ….
