Need a photo or two and maybe some measurements
'69FuryIIIConvertible
Fixer of junk
Newcastle, Ontario, Canada
I had to cut the Seat back brackets off in order to do my frame work, so I need to put these back, Can anyone tell me some measurements or get me some photo's of where they should be please.
Nick
Well, if you don't get pics/ measurements, then measure the distance from underneath your rear seat frame. That should get you what you need.
are you looking for the placement of the lower brackets?
driver's side: 12.75" from the metal wiring cover to the right edge of bracket
passenger's side: 13.50" from wiring cover to left edge of bracket
both are 4" from the kickup in the floor to the front edge of bracket
tallest part of the bracket goes to the front of the car
if you need the uppers i can get those measurements too
Thank you Jim, that is exactly what I needed!
no problem, i have the seats out anyway to repair the floors. not sure why the spacing of the brackets is different side to side. to avoid the seat frame bracing maybe?
