Need engine pictures of a 67 Imperial.
Cadee
Ontario, Canada
I'm looking for as many pictures of the engine and it's compartment, on a 67 Imperial.
I purchased a Crown Sedan recently, and some things under the hood/engine don't look correct, so I'm hoping that some members here can post some pictures of their original, or as close to original engine, and any other under the hood shots.
Thank you.
I can provide those but I don’t have any handy, I’ll post up tomorrow.:thumbsup:
This is largely correct.
Thanks for the pictures. Two things, someone has painted my engine Chrysler Blue, I see yours looks more like turquoise. Which is correct?
Also, on mine, the breather cap on the drivers side valve cover has a hose running from it and it connects to the bottom of the air cleaner, I don't see that on your pictures so maybe someone changed it on mine?
not sure which is correct, mine or your's...I assume yours.
Thank you.
Your engine should absolutely be turquoise and if your car had the cleaner air package the extra hose to the air cleaner might not be incorrect. Pics would confirm.
