Gerald Morris
figured i'd give you a laugh...in the process of painting all the stuff for my rebuild i noticed my cable bracket was twisted to hell...so of course i straightened it properly....well i just tried to hook the cable up and realized the previous idiot had to twist it to get the cable to line up with the carb...cause there's an Edelbrock performer 440 on it which evidently is a taller manifold (despite reading that the performer is stock height and only the performer RPM is taller)...so i'm off to the shop to cut up the stock bracket and angle it correctly...
(chuckle) Yes, Edelbrock INSTRUCTS customers to twist and otherwise bend their stock bracket to accommodate their carbs. I found the throttle bracket and kickdown bellcrank for the 1968 engine I bought IN that ragtop last September with the NAPA reman Carter BBD and guess what? IT'S THE 4 BARREL THROTTLE BRACKET!!! I might add that unlike this paperweight I bought from Mancini, it holds it's bellcrank pin firmly in place. Reckon I'll clean it all up nicely, repaint it in Old Chrysler Turquoise, and maybe try it out AFTER I resolve the power steering pump issue which arose just a couple weeks ago. Today, after I finish haggling w State bureaucrats over Family benefits, I plan to draw some fluid off the pump to give it "the Pink Test." If it tests Pink Positive, I then will KNOW a certain Chebbie Chimp merits a Lead Enema, though alas, I won't administer it. Folks here have got funny ideas about medical practices of that sort.
