78Brougham
"Chump"
Mine was out for the first two years in my imp. Got to it when I had the chance. Luckily I've had them apart before and it just needed a good lube job.
I may have to get some pointers whenever I get around to it.Mine was out for the first two years in my imp. Got to it when I had the chance. Luckily I've had them apart before and it just needed a good lube job.
I'm glad you've got her all sorted out...I took her out for a short drive this evening. I may take it to work tomorrow, even though the forecast is wet.
Good on you John. Now remember, No more car heart attacks in the wee hourz in turn pike toll boothz, Jer
On closer examination, the battery cable terminals looked good, but I could see something between them and the posts. I pulled the positive cable for a closer look and found a thin layer of "accumulation". I dug out a battery terminal cleaner I'd gotten at a road rallye a few years prior. Cleaned the terminals and posts. Still had voltage "everywhere", but now it started reliably. Possibly the accumulation was allowing "volts" through, but not "amps"?
I never did get around to crimping the red wire's terminal at the inside bulkhead connector. I got to the filling station and it wouldn't start. I quickly looked under there and pushed the red wire back onto the terminal a little tighter. Made a mental note and drove off. With the open area under the dash panel, no real problem to check it, that was about 10 years ago. Still need to crimp it!
ONE thing I'd done was to install the Mopar Perf electronic volt regulator that was supposed to go with the electronic ignition. When re-reading about it in the Race Manual, it noted that it kept voltage at 14 volts "which would affect longevity of all electrical components in the car, including light bulbs". That was probably why the earlier issue with the red wire happened? After deliberating, I put the orig voltage regulator back in. The ignition worked fine so that's still there. Some replacement volt regulators have normal electronic guts in them, under the normal-look cap, but I've still got the "points-type" regulator on the car. Orange boxes and that "constant voltage" regulator are NOT needed for the electronic ign kit to work!
