No Spark after unplugging coil wire...FIXED!!!!
Sorry it took so long to get back. The air gap on the distributor was set wider than .030. After adjusting to .008 it seems to have fixed the problem. Thanks to all who gave advice. Now i can take her on the maiden voyage........and see what else needs fixed. Also thanks Big John for air gap procedure link.
Good!
Next...
I had a Cordoba that would do that. It was the pick up coil in the distributor. It would not create the sine wave to trigger the ECU when hot.
You can probably check the wires coming out of the dist for a voltage spike (very low voltage) when cold and again when hot and see if there is a difference.
