I bought probably the same gas tank from Van's a couple months ago when they were on sale. The box seemed sturdy enough, there was extra cardboard pieces along the sides to give added protection. I haven't done anything with it yet, I guess I'll have to put a few gallons of gas in it and rotate the tank on it's sides and see if the seams leak? Or maybe seal it up and put some air pressure in it and see if it holds.
I have a previously acquired sending unit that I'll be putting in there, I didn't buy one from VANs, but I would expect to have to adjust the pickup tube and maybe even float arm to fine tune their position and motion range. I don't see that as a fault that you need to do that. I'm also going to install (solder) in a ground bolt to the sending unit round mounting plate because the factory way they had setup to give a ground connection to the sending unit is hokey.
It was mentioned earlier in the thread that these are Spectra tanks? I don't think they are. These are made in Taiwan, I thought Spectra tanks were made in US or Canada. ?
