Here ya go.
That's a pretty good deal there but not ideal for lower RPM range as I'm sure you now. It is a good example of a what you can get for the price though.
But i like the Torker and Torker II.
Here ya go.
I thought you had a 383, that won't work.What do you guys think about this intake?It's off a 1971 440...casting# 3512501 http://www.ebay.com/sch/i.html?_trk...intake&_nkw=3512501+intake&_sacat=0&_from=R40
Would I be better off with an AVS?
I am confused...do I need a manifold only from a 383 engine? Will any other engine models fit?I thought you had a 383, that won't work.
I have a 6454 TQ in a box if you are Interested.. Book says it is for a 1974 360 HP California manual transmissionHey Stormer, I am not traveling unfortunately.I have been told to look for a '72 to '74 TQ ....model no. from 6090 to 6616 I think.If you have one of the early ones, what would you sell them to me for?Thanks,Mark
361/383/400 are B engines and would share the same intakes.I am confused...do I need a manifold only from a 383 engine? Will any other engine models fit?
Thank gawd you picked up on thatI thought you had a 383, that won't work.
My mind is very clearThank gawd you picked up on that
RE: The carb.
I think a carb original to your car is best.
Not an off the shelf rebuilt from XYZ Carb Repair and Vinyl Siding, Inc. but one expertly restored (not rebuilt) by a specialist. And it will probably cost more than a Summit Edelbrock or Holley but those carbs out of the box suck anyway...
They are Universal carbs meaning that they were not designed for any specific car in the Universe.
Somebody around here actually took my advice.I pulled the trgger on a Carter AVS code# 4401s
It is the oem carb for this application and appears to be in good nick
Ross would be 1/2 way through a FAST FI conversion on your car by now with another year of sorting through the last half.
