2 barrel Intake manifold for 318
DirkRhodie
Durban South Africa
Was there an performance OEM 2 barrel intake manifold for a "67" 318?
I have a slightly modified 318 and want to use a 500cfm carb on it for various reasons.
Here's the issue I reside in South Africa so parts for Mopar are extremely difficult to find so any help would be greatly appreciated.
No. There were open plenum manifolds but none were specifically for preformance. 500 2 barrel carbs will require an adapter.
Agreed, the 318 was a "bread and butter" engine by that time and no performance 2bbl intakes for it.
If you need a higher-cfm 2bbl, the next-up option would be the 1.56" throttle bore Carter BBD 2bbl for the 383 2bbls. Chrysler never did use a 500cfm-area carb, BUT GM did, starting in 1957 on some Pontiacs. Later to on-and-off use them on in the later 1960s-middle 1970s on Chevy V-8s and some Buick 350s, too. At least for USA-spec engines. To use the Rochester 2bbls, you'll probably need the same adapter used for aftermarket 4bbls to mate the GM linkage to the Chrysler linkage set-up.
To me, these big Rochesters drive just as good as a spreadbore QJet carb, up to about 3/4 throttle on a Chevy 350. Might not quite be 500cfm, but probably about 450cfm. Putting a 500cfm Holley 2bbl on an intake manifold with existing 1.44" throttle bores will mean the 500cfm carb will NOT flow to its rated potential, but less, with the adapter. Yet the adapter will be needed to interface the Ford mounting pattern to the normal mounting pattern, anyway. Probably better all around to machine the mounting flange to the 1.75" throttle bore diameters and use a factory base gasket than not.
With a drill press and hole cutting lathe, you could enlarge the existing holes in the throttle flange pad to 1.75" each. Then drill and thread new mounting holes for the bigger bolt patter. You can find an illustration of those gasket sizes in the Holley Sniper 2bbl service literature, as I recall. Yep, Holley Sniper EFI 2bbl models.
There were a few years, about 1968 or so, where the OEM 318 2bbl manifolds looked very much like a performance single-plane intake manifold. Still carried the same power and torque rating on the motors, though, but they did look neat. If you need more torque, a massaged dual-plane might be best.
Possibly you mean a dual-plane 2-bbl intake? See this:
Was there ever a small block / 318 dual plane 2-barrel factory intake?
Or this (look at post #24 and later)
Question about buying Carter BBD for my 318 (unless I should look at something else)
Also these might be of interest:
EPIC 318 Mission Impossible Mopar build is Back (Unity MotorSports Garage - 3 months ago)
This is a work in progress, goal to get solid dyno numbers on stock 2-bbl 318 and go from there.
Flow Testing a 2BBL Carter BBD Carb for Project MISSION IMPOSSIBLE + More!!! ‪
UncleTonysGarage‬ (2 years ago)
Carter BBD flowed about 250 - 260 CFM
This thread gives some CFM numbers and math for the /6 and 318, with a bit of a focus on the Super-6 2bbl carb:
How to improve CFM flow in a BBD from a 78 Super Six
I forgot about the LA intakes being the same for all motors, just maybe the port size at the cyl head was different. BUT the 360s also used the 1.56" throttle bore carbs, except for the 1980 models which used the smaller 318 1.44" throttle bore Carter BBD.
There is also a YouTube channel "318 will run", or something like that.
