Oil Pressure Gauge Install
Some devil's-advocating...
Plastic tubing can come in 2 versions - 'unknown' plastic, and a higher-capability, higher-quality nylon.
The other plastic is Abomo-Basico-Sino-polymerate. Cheap, bottom shelf stuff to be sure.
All teh horror stories you hear of an oil leak will blame the line, without a detailed determination of what truly might have caused it.
Having these polymers in proximity to anything hot does them in. In my case, it had slipped too close to the exhaust manifold, which, happily, annealed it shut.
For me, I want a 270° sweep on my oil and water, for better resolution on the numbers, and that's expensive in an electric gauge, 90° is most common.
I like mechanical gauges because I can watch my T-stat open/close several times before it settles to equilibrium operating temp.
And when I get closer to oilchange time, I'll see the slightest bit of needle-quiver in my oil pressure at idle. (I don't quite understand it, but have seen it happen enough times to recognize it) An oil change makes it go away.
I strongly suspect the needle quiver arises from the inevitable breakdown in oil viscosity and homogeneity after so much heating, pumping, impurities et al work to increase entropy within a MIXTURE masquerading as a SOLUTION. I suppose single viscosity synthetic esters might truly qualify as pure solvents, only degrading as the entropic processes aforementioned work, but all others are at best near homogeneous BLENDS, even if composed of pure synthetic esters. This state invites more rapid decay from Time t0. This remains the greatest cause for more frequent oil replacement with refined mineral oils versus synthetic oils.
To wit: the oil gets lumpy with age.
Good point, but not an issue with my install. I use this. Extremely rugged, the senders screw directly in just like the block port, no long piping to wiggle and shake. Bulletproof.
I would not recommend a contraption like this one. :D
What sealant do you use if it doesn't come with any? Just regular red blue loctite?
No sealant. Pipe thread seals against the male OD and female ID threads by being tightened together. It’s a taper fit.
Others will tell you to use Teflon tape. But Teflon is slippery stuff and can allow a fitting in a high vibration environment to unscrew itself. Tighten the fittings like a man and be done with it. But not TOO tight!
Oops I didn't even notice that this was an old thread. I thought it'd be NPT - that needs sealant doesn't it? Never been a fan of teflon tape in these applications because when you remove it, you can get bits of it inside the system.
I believe that I made it clear that sealant is not necessary on these NPT fittings. Tighten them. That is the concept of pipe thread.
Teflon tape in this application is worse.
But if you want to use some goop or thread sealant….have at it.
Actually, NPT threads do not seal on the threads.
The threads are tapered, so when it's tightened, the flanks make tighter and tighter contact.
But at the root of the threads, there will be a leak path that spirals all the way out.
So in some applications they will leak without a sealant. (water is one example)
Engine oil apparently has enough thickness to not leak.
