68NewportDDD
Well Good morning C Body fans!
OK, so I did it again...I bought this '66 Fury VIP in Manassas a few months back:
NOT MINE - 1966 Plymouth Fury VIP 63,000 original miles $3,500
Turns out it's a GEM! It needed new wheel cylinders in the front passenger so I went ahead and replaced that. While bleeding the lines the seals on the driver side wheel cylinder gave up the ghost but I was already prepared to replace both sides along with the brake lines.
Now I am thinking I should probably go ahead and replace the shoes as well but all is not as simple as it seems. I came across this thread that pretty much sums up my confusion in a nutshell:
Brake shoe sizes
So I am thinking I should reach out to the OG's on the board and see what the major consensus is.
The Fury has 3" wide drum surface, 11" diameter drum (inside measurement), and the shoes currently on it are 2.75" wide. Alot of the car is original, 65k miles so I am guessing the brake components (hopefully not the shoes nor the brake fluid) are original or at least OEM.
From my initial research and shopping around I find that indeed there are about 316.84 different brake shoe sizes available but ONLY ONE that is right for this car. And since the wife has claimed this one as hers I am thinking that I should probably get it safer than I would if I were the one driving it.
So what do you think?? Any recommendations on shoe construction (bonded v. riveted?) Braking shoe material? Any particular supplier or manufacturer (MOBILEPARTS)
Any help, insight, criticism is most welcome!
Brake shoe sizes
