Tink
Just for future reference. https://durathermfluids.com/pdf/techpapers/pressure-boiling-point.pdf
It receives water.How will the water pump work without receiving water?
my method for a complete and thorough flush.
1. Remove thermostat and reinstall the housing.
2. Disconnect upper radiator hose from radiator and direct the flow coming out of the block towards ground.
3. Set car heater to max.
4. Make sure radiator is empty.
5. Add chemicals of mass destruction (your choice) to radiator.
6. Insert garden hose into radiator.
7. Start engine and wedge something in carburetor linkage so that it runs at a high idle.
8. Turn on garden hose so flow of water matches flow of water coning out of upper radiator hose.
9. Run, run, run, until water coming out of upper hose looks clean enough to drink.
10. Add small amt. Of tide laundry detergent to radiator.
11. Continue flushing process until soap coming out of hose is gone and water is crystal clear again.
Stop engine.
12. Install new thermostat (180° minimum) and gasket and upper hose.
13. Drain radiator again andd a/f to radiator until full.
14. Restart engine and bring up to high idle again.
15. Purge system of air completely, and add additional a/f as nec.
16. Dispose of dead animals who you indvertantly let drink the old antifreeze flowing down driveway.
Wash down driveway to remove evidence.
to divert the coolant coming out the upper hose away from you and the car, i found that a hose from a shop vac is the same size.
PS.....if you can, use a blow gun and compressed air back and forth top to bottom, bottom to top a few times. Just regular l ate the air pressure to around 15 psi!!!!!!!
Hey guys, it's been a while but I figured I would post an update now that I have finally been able to get some stuff done. Back surgery sucks!Well any update? Did you solve the overheating?
I can personally attest to the efficacy of this product. I used it in my '69 NY, whose 440 block had a significant amount of scale in it. I drained the system, knocked out a freeze plug, put in a rubber expansion plug, filled it with Evapo-Rust and waited. At the prescribed time, I removed the expansion plug and let the Evapo-Rust drain, flushed the system, refilled it, and I have not seen a speck of scale since. It worked for me.Evapo-Rust has a block cleaner that looks very promising. I may give it a try myself.
