thrashingcows
One last thing, timing, I was attempting to use the fitech for timing with the stock chrysler electronic distributor. I did have overheating issues and went back to the stock box on the firewall. Didn't run very well. Kept misiring and hard to start. Fitech recommends getting a HEI style distributor (expensive) so I will play with that when the finances allow it. So if you tried the same thing that could be an issue. Mine runs very well without the computer control so it's not a major issue.
As I think about it I did replace the timing chain back in the mid 80's and it did help with overheating too.
I was doing some tune up work on my 440 years ago and accidentally hooked up to a ported vacuum source for the vacuum advance so i was running too much timing for a couple days. Due to the timing I was overheating and puking fluid out and it took me a bit to figure it out, but once I did no more overheating problems.
