70NPORT
Its too friggin hot
Its too friggin hot
Do you or anyone know where I can find recommended torque specs when installing an aftermarket aluminum water pump housing to the original Mopar 440 engine? I'm also installing a new aluminum water pump to the new aluminum water pump housing.You're sure you scraped the top surface of the water pump housing down to shiny metal?Don't use 2 gaskets whatever you do and make sure you are using the proper torque spec. Check the billet aluminum thingy for flatness by laying a sheet of 150 grit sandpaper on a hard, flat surface like a granite countertop or a thick glass shelf and rub the housing on it a couple times. Check and rub till uniform.
They are 3/8" bolts so 45lbft would be max. I would probably be around 35 if I was going to measure.Do you or anyone know where I can find recommended torque specs when installing an aftermarket aluminum water pump housing to the original Mopar 440 engine? I'm also installing a new aluminum water pump to the new aluminum water pump housing.
After poking around on the internet, I just ran across this site >>>They are 3/8" bolts so 45lbft would be max. I would probably be around 35 if I was going to measure.
No, why? You need clamping force.After poking around on the internet, I just ran across this site >>>
Mopar Bolt Torque Specifications – Big Block
... where they list what looks like stock (cast iron) torque specs and show the water pump at 30 ft-lbs. Any thoughts on reducing that for an aluminum water pump to something a little less?
I'm leery that if I apply the 30 ft-lbs, it may damage the aluminum water pump housing since the torque spec is for the cast iron water pump housing. I'm guessing at least 5 lbs-ft less to tighten against the aluminum water pump housing.No, why? You need clamping force.
Your making a problem that does not exist. Needs to be tightened evenly, and not overtightened.I'm leery that if I apply the 30 ft-lbs, it may damage the aluminum water pump housing since the torque spec is for the cast iron water pump housing. I'm guessing at least 5 lbs-ft less to tighten against the aluminum water pump housing.
