cm23uoc
- Joined
- Feb 13, 2011
- Messages
- 8,368
- Reaction score
- 3,445
There are different widths available to suit your needs, I used a 9 millimeter band, should have gone with a little more narrow one for these rims of mine.
When I restored the SSI (Magnum 400 style) wheels on my Olds a couple of years ago I used Stan's method of masking, outlining and trimming using regular masking tape (and I figured that out all by myself since I didn't know Stan at that time!). Worked fine, didn't take too long.
I'm going to check if Home depot has it today.
When I painted my road wheels I used electrical tape to do the edging. Same principle as the blue Scotch, but 1/2" wide.
The trick to avoid bleeding and get a good clean line is to put a couple of REAL light coats on over the tape line. Then let it dry for about 10 minutes before putting your full wet coats on. This will bridge the tape and surface and eliminate bleeding. Using regular masking tape this way will give you the same results as using more expensive fine line tape.Interesting. No bleeding?
(Sent using Forum Runner)
Excellent idea, 100% agree.
x3+.............x2 Thanks Chris!
Did you find the center dome yet?
