70bigblockdodge
Wow, all this aggravation to eliminate points in a car you are going to put what maybe 1500 mi a year on, and most likely never going to spin past 4500 rpm. Now at least when the petronix module goes bad you will know right away to call the tow truck and order a new one from Summit/Jegs whatever, because there is no fixing that on the side of the road with a couple of trinkets in the glove box.
Guess that's why I will never get a TV show, no product pimping.
Your car should not be dependent on spinning it over fast enough to generate voltage to make a spark. Go look up Ohm's law.
The coil fires by collapsing a magnetic field over windings. If the circuit opens the field collapses causing a spark. The field is created by amperage(current) flowing through the heavy primary windings in your coil. When this amperage stops the field collapses creating a high voltage, low current energy which jumps across the spark plug gap, BTW not electrically connected to 12volt of car. The voltage of the battery has little to due with creating a spark at the plug.
