70NPORT
Yeh forgot about the other end.Theres a "sock" at the end of the pick up in the tank also. You might consider checking that too Gary.
No screen in there.Is there a filter/screen in the carb?
Yea Bob I have two spares, thanks for the suggestion, thats something to consider also. I've try that. I was out this morning and did have any issues so, who the hell knows.When you're done playing with the fuel system....
Do you have a spare ignition coil?
I would swap the coil and see if your starting problems go away. It takes 2 minutes to swap.
A bad coil at the end of it's life will cause a no start situation "like it's a fuel problem". The engine won't start....let it cool for a few minutes (coil cools down) and then the engine will start. Eventully the coil will quit all together.
It's probably something stupid and simple I am overlooking. Getting hard to find nice early 70's BB fuselage coups that are all busted up to hell and raggedy anymore....think I'll keep this one for a little while longer unless something falls into my lap....again, lol.How come all your problems are always the most complex to troubleshoot.
That car hates you. Time for a new one...![]()
ok coil swap made no difference this morning. Another clue however. Coming back I had to nail it to get around a stinky trash truck. As I passed around there was no other traffic so I let it hang out a bit. Not sure where my rpms were at but 80mph came up fast and then for like half a sec the engine almost dies out, twice, almost like the fuel supply was suddenly cut off. I let off the gas and everything goes back to normal. Other than this the 383 has ran great since I installed a new intake manifold and had the heads redone.
Yeah and how.I had those symptoms when I had a six pack on a 71 440 Polara....it would starve at 100mph. Different reasons but that blows when you're into it
Not right now. My springs and stuff are in transit. I'm just trying to shoot down simple easy to fix crap I might be missing. If its a pump related issue I'll rectify it while the car is down. That WOULD blow however. The damn pump aint barely four years old. It replaced the O-R-I-G-I-N-A-L pump which still worked but I swapped out to be sure since it was decades old. Shoulda probably left the damn thing in. I been kinda thinking about going electric. Just trying to convince myself I really need that.Not being funny but like was suggested earlier...
Your pump rod?
I know Bob, i think someone put a hex or something on me. All n all it could be worse.Dang Gary.......this car is cursed!
