The text that accompanied this Lamborghini plant pics is interesting.
" The original Lamborghini factory, established between 1963 and 1966, encompassed a 12,000 m2 facility that housed production zones, offices, testing areas, and a service workshop. This factory had two main production lines: one dedicated to engines and mechanical parts, and the other focused on the assembly of cars, including the renowned Countach. By October 1968, the factory was set to expand, adding three new buildings that increased the covered area by 3,500 m2. Today, the factory spans an impressive 346,000 m2. Remarkably, the section known as the No.1 Countach Assembly Line, where the vintage Countach models were meticulously assembled, is still in use.
During the Countach era, the assembly line was characterized by its simplicity and manual-intensive processes. Body panels were hand-shaped and then verified against wooden templates before being welded and adjusted on the car body mold. This careful, hands-on approach was crucial because, although each part appeared identical, slight variations were common due to the manual production methods. The assembled body, crafted in raw aluminum, would then be united with the frame on an industrial trolley that moved between assembly stations, where various mechanical components were installed.
This bespoke process extended to the interiors, initially made with external partners, evolving into an in-house upholstery department specializing in custom leatherwork."
