MightyMats
This is a long post.
I am sure this has been done somewhere before on the internet but I wanted to bounce some of my own ideas off you senior guys who have been around the block once or twice.
Goal: I want to build a bulletproof twin turbo 400 that will run on 93 Octane and not blow up
Horsepower Goal: Above 800hp/Close to 1000
Budget: 15k without machining. Or Turbos
I have been thinking about doing this build for awhile with a 440 but it just doesn't seem right. The heavier rotating assembly of the 440 coupled with a longer stroke doesn't really seem ideal for what I am shooting for here. The shorter stroke and lighter rotating assembly should help this thing rev more and the bearings will appreciate it.
I don't plan on stroking this block. It will need an overbore but thats the extent of the cubes I want to add to this.
71 400 block. $400
BCR's cap and girdle system. $800
4340 Forged Crank. $800
Lightweight rods: $600
Pistons: $800 + $150 for Rings
Chromoly pushrods: $130
Heads: $2500
ARP Head bolts $200
Intake: $400
Cam Gear Drive: $700
Cam Shaft + Hydraulic Rollers: $800
Distributor: $500 w/wires
Oil Pan: $300
Valve Covers: $150
Blow Through Carb: $600
Headers: $600-800 for materials (i'll build them)
Cam/Rod bearings: $300
All the misc I can't remember(valves, retainers, oil pump, fuel pump) : $1,000
Total: $11,930 (i'm probably under bidding this)
Here are some questions I would like to bounce off you guys. Since this is a turbo motor (my first) I don't need huge ported heads that flow 350+ CFM at .500 lift because the boost will help feed the engine the air it needs at higher RPM's right? Thoughts?
71 400 block. $400
Heads: $2500
ARP Head bolts $200
Intake: $400
Oil Pan: $300
Valve Covers: $150
