Power steering spool valve adjustment
Chris RB
Toronto, Canada
Well, I made the mistake of screwing with my power steering to fix a leak and now here we are…
I’ve got the car off the ground, when I start it up, the steering wheel is still. As soon as I turn the wheel in one direction or the other, it’s just keeps going. Tapping the valve block has fixed the unbalanced assist but I don’t know how to make the wheel stop spinning following my inputs.
Any help is greatly appreciated.
Cheers,
Chris
Did you see this thread:
Long story short - I also changed a seal to fix a leak. The steering shaft (worm shaft) seal. I didn't take much of it apart, but I did mix up a couple parts, I corrected that, but I still end up with a very touchy steering gear that wants to turn the wheels in either direction if given the chance. I've lost the wheels self-centering ability when the car is moving. I'm going to work more on this over the winter, I have a spare steering gear box that I can putz with at the same time.
But definately post here what you find about yours.
Will do, I'll probably post a video tonight of the steering wheel on here as well.
Well, after redoing this thing 3 times I've finally fixed it...
Turns out it was the O rings I replaced. The ones I put in were so close to the original ones that came out of it but were ever so slightly thicker. I wouldn't have thought this would have made a difference but it did.
I bought a seal kit from Rockauto: "Edelmann 8518", as they were designed specifically for this job.
I put it back together and all my steering problems were fixed.
Hope this is useful information for someone.
Cheers,
Chris
Cheers,
Chris
Are you talking about this o-ring?
Because the spool valve itself has no o-rings on it.
