bluefury361
I'm having a problem trying to get the power windows on my 69 300 to work right.
The left front door and right rear quarter windows work great now. The right door glass goes down but not up and the left 1/4 glass goes up but not down. All the motors work both ways when powered up individuality and the switches check out ok.
After two days of checking circuits I now have two broken wires at the driver door gang switch, (broken pin connectors in the switch connector), so it looks like I need a whole new connector and pigtail, (or harness). And I still don't know what my problem is... :tantrum:
Also..... The license plate light. It has two contacts and I have power to one. The bulb, (GE 85) has two contacts and only one filiment. Although there is current present at one contact the bulb does not light, (new bulbs and a good ground). The circuit guide in the factory manual shows only one wire to the socket. Does anyone know how this lamp circuit works...?
Thanks, Will.
Thanks, Will.
