I was mocking accessory parts back onto the rebuilt motor and found that the 3/4" exhaust manifold stud as provided by the rebuilder was not long enough (that's what she said) to fit the manifold + spark plug wire support bracket + A/C mounting bracket. So I put double nut on there and after a while stripped the threads on the stud. so then I put vice grips on and a pry bar and was manually unscrewing the stud. then it broke flush off.
so THEN I drilled out the center of the broken off exhaust stud from about 1 c. hair up to almost 3/8" the size of the stud. Put in the easy out. leaned into that and the tip of the easy out broke off in the pilot hole..
then I packed it all up and didn't work on cars for a few weeks. got some money up and took it back to the rebuilder. he didn't want to touch it but sent me to Delbert hoops machine and welding 600 ft. worth dr denton TX. Delbert took great care of me and it, and extracted the broken pieces and chased and cleaned it all up, and installed the new stud I had brought with me. 100 bucks.i gave him and extra $20 and said the lap dance is on me.
on sept1 we had the mopar show in garland, and out of whatever hundred cars, 0 are set up like this.. w/AC w/PS and this style ALT bracket and the big wheel P/S pump. I saw plenty that were rigged up with shims and spacers, even on 'show' cars. also many ppl have converted or added the vintage air sanden type setups for their A/C. most that the smaller style P/S pump in this configuration. Or the alternator bracket was different (under not over).
so I did some figurin, and think I have worked out the belts and mounting of the P/S pump. I guess I had a bracket that does not belong, as I removed it and then everything went together and looks to line up.
17435 P/S belt w/big pulley wheel
15650 x2 AC/ALT belts
15360 fan belt
