I’m looking for some input from any suspension experts we have here.
Here’s the issue: I recently started driving my ‘72 Polara. It didn’t run good enough to drive when I first bought it so I had to deal with those issues first,,now that I’ve got it on the road, it pulls to the right. Not real hard but , bad enough that if you let go of the wheel you’ll be in the ditch pretty quick.
The brakes don’t seem to be dragging or getting hot but, when I apply the brakes the car corrects itself and when take my hand off of the wheel it doesn’t pull one way or the other. As soon as the brakes are released it goes back to pulling to the right.
Ive checked the front end parts and they all seem to be tight enough not to cause this issue but, I wouldn’t rule out “stacked tolerances” causing it.
Also, a string and tape measure check in the alignment didn’t reveal any questionable information.
I haven’t done a close inspection on the rear axle. I kinda suspect that the centering pin might be moving in the hardware that holds the axle to the springs. It’s the rubber insulated torsion air ride stuff common on our cars. Seems like I’ve experienced this issue before, but I can’t remember for sure.
Anyway any thoughts would be appreciated.
