commando1
NO. NO. NO. We've discussed this before.......Now who wasnt thinking? No change needed for the frame, it bolts right in. A radiator, transmission, drive shaft, and manifolds from a donor is all you need
You're gonna end up with a rainbow tattoo at the rate you're going.I can never do that with you. I don't feel like trying to play soccer with a bowling ball.
......................................Yes it's a 360. Over on that blues brothers forum that every here is so disappointed in they found there actually are slight differences in the big block and small block sub frame. And there's a derby guy who says that you can drop a small block into a big block frame, but it's difficult and offsets the transmission. So it'll fit, but it causes severe binding on the mounts, which is the assumption and questioning coming into play about a big block into a small block swap...
Here's a link to the thread with an excessive discussion about the frames, if anyone wants to venture over to the dark side"
http://bluesmobiles.proboards.com/index.cgi?board=details&action=display&thread=370
You're never too old to learn.
I'd drop a built SB stroker before going through the hassles of modifying the frame for a BB swap.
no............................
Fine......
It bolts right in then.
prove me wrong
Thats because I dont argue unless I know I'm correct
Zac, the guy in Maryland that I got the road wheels from has a BB subframe (with a BB mounted on it) on wheels sitting in his driveway.
