When I was doing my suspension the general consensus on the board was either the torsion bar is either good or broken, confirmed by PST . They recommended, if they weren't broken or if I didn't want a stiffer ride, do not change them.
I think you have something together incorrectly or something is broken and you don't know it.
I have seen this uneveness of torsion bar adjustment numerous times and believe it is primarily due to the heat treating process in making the torsion bars in the first place that cause the bars to weaken at different rates over time. Back in 1957 when torsion bars were first introduced on Chrysler products, there were many issues of some bars suddenly breaking without warning while most did not and it was ascribed to variations in the manufacturing process that had to be tightened up. I believe the PST recommendation not to change them is acceptable if everything else is normal given the nature of the issue. Generally ride and handling are not affected significantly by this reality in my experience and the ability to align the vehicle is not either (but worn bushings or other similar issues will affect alignment capability).
I also believe a consensus is general by definition...............
