Well after alot of work finally got the newport running and back to normal, my question is I put one of the pertronix dist kits in, gapped it properly to .30. The car starts right up the only thing is when i put it into gear it wants to stall. We messed with the idle still did it. The idle also goes up and down, maybe the kit is no good or I need to mess with the mixture screws, any help would be appreciated, motor is a chrysler 383, did a cam upgrade, lifters, springs, 650 cfm carb. Stock distributor in good condition.
