Radiator, recore or replace?
JC68vert300
Ocean County, NJ
Just noticed today the radiator is a little wet along the bottom seam. No antifreeze on the floor and the level is fine. Just doing my usual inspection under the car. A/C car. Would like opinions on recore or just replace. I am leaning towards a recore. There are still some good radiator places here.
Fingers in North Brunswick and Hawthorne Industrial in Wayne. All well north of me. Thanks Jim C
My first thought is to re-core. Was the radiator cooling well? Is the core bad or maybe just a seam in need of re-soldering? I have had several re-core jobs done with excelent results in all cases. I have usually added an extra row of tubes when "in the business", just for insurance. Lindsay
I have often heard of replacement radiators not holding up as well as the originals. It may not be cheap or quick, but I'd recommend re-coring..........
I just had one recored and it came out nice.
Are you sure it's leaking? A little bit of "wet" along a seam could be a lot of things... Overflow, spillage etc.
Fire it up and see if it holds pressure.
Ditto on the recore if it needs it. Trouble is finding a place that actually does them. The guy I used a few years back retired, but still does them on the side out of a friends shop.
Re-core. You are fortunate enough to have a few old school rad shops in your area so take advantage of that.
my gut feeling was to recore, but I have seen so many aluminum replacement radiators at cruise nights and car shows that I started second guessing myself. Thanks for the feedback…100% in favor of a recore. The radiator is cooling the car fine. it looks like it is a seam that needs resoldering, but if it’s coming out of the car for the first time in 55 years, I might as well have it done right. I will use Fingers Radiator hospital. My neighbor used them for his 72 Dart, and was happy with them.
Fingers Radiator Hospital is located on rt1 in New Brunswick, NJ off exit 9 on the NJ Turnpike.
Well, the radiator was in worse shape once we got it out of the car. I hadn’t really paid much attention to it since it hadn’t been losing antifreeze. The car also never ran hot. $625. Plus tax and 10 days at the radiator shop and it is ready to go back in. Here are before and after.
