FinallyGot1
Hello all! There's a disturbing growling coming from the rear end of my '68 Newport. It doesn't seem to change much with throttle setting or speed and is still there when coasting in neutral. I suspect axle bearing(s). So here's my plan: Rebuild the rear end with new axle bearings and any seals I run into. While I'm in there, I thought I'd throw in a TrueTrac differential and a set of 2.75 gears. (What can I say? I like my girls with long legs.) I've been unable to find gears anywhere near that tall for my 8 3/4" rear end though so any help on this would be much appreciated. Already tried Summit, JEGS, and any number of miscellaneous sites and no joy. 3.23 is the best I've been able to do.
Should I also consider replacing U-joints while I'm under there?
I'm trying to get the driveline prepped for a stout motor in the (hopefully) not-too-distant future and I am much more interested in keeping my revs down while cruising the highways than laying rubber from a stoplight.
So. Any thoughts, info, or advice you care to share would be much appreciated.
TIA,
Jason
TIA,
Jason
