I need to remove the rear trim cards from both sides on a 69 Fury convertible, can't seem to find anything about them in the service manual - does the rear bench need to come out to remove them? Are there any clips likely to break I should be aware of? I can see one screw on the panel edge where the doors close, and I imagine there are one or two in the arm rests.
On one side the window winder slips and on the other the glass isn't adjusted properly and there's a screw trying to stick through the vinyl from the inside outwards. I found the glass adjustment instructions but I need to know how that trim comes off without damaging it.
Apologies if this has been answered before, I couldn't find anything in the search but I may be using the wrong terms.
