D Cluley
With the bows all back in place, I moved on to the pads. The fabric of the old ones is still in pretty good shape, but the foam has all disintegrated, so new ones going on.
They have a piece of heavy fabric underneath the foam insert & lighter fabric flaps that fold over the top.
I lined up the edges with the indent on the front header & put one screw in to hold it loosely, then lined the pad up on the intermediate bows and put some staples into the tack strips.
When I ordered the top kit last year, they suggested that a powered staple gun would make the job easier, so I picked up an electric Arrow gun. It uses the regular T50 staples, so I'm sure it will get used for plenty of other things as well. You do want to get stainless steel staples for doing a top.
Once the pad was secured in the middle, I went back and put the rest of the screws into the header.
Once the intermediate bows were stabilized firmly with the pads, I used a bungee cord to pull the rear bow forward tight against the short tension cables, and stapled the pads to it.
Time to sit down for a break. It's kind of like a big panoramic sunroof. You know, except for the keeping the rain out part.
So, moving on the exciting actual top parts, I measured & marked the center line at the base of the rear window. Measuring the vinyl at the top of the rear curtain, there is a stitched seam that falls in the middle. I measured the old curtain and marked how far above the zipper the staple line should go in the middle and at the edges of the new rear window.
I finished up the evening by stapling the curtain to the rear bow. This feels like actual progress.
