Routing for 65 Fury Turn Signal Wiring
65Fury440
West Central FL
I am in the process of getting the lighting working. Where does the wire run from the connector under the left side in the trunk, up the deck lid and feed the reverse and inner turn signal lights?
I tried the FSM, no mention of it.I was hoping someone could take a quick peek. The Fury III and Sport Fury should be the same.
On my '66 Sport Fury the wire clips onto the left side of the square hinge bracket that's attached to the trunk lid, wraps around the back side of the hinge bracket and into a 2" hole just inboard of the hinge mount on the trunk lid. The wire then runs inside the longitudinal stiffening rib/channel on the left side back to the lights.
