You will need a 4 groove crank pulley. I have one I can sell you if you need it.So Commando...what pulleys are you using? Is your crank pulley 2 or 4 groove? Water pump is 2 groove? Any pics of pulleys and how belts are routed? What length belt did you have to switch to? Thanks!! Looking close at your pic, I see how AC is routed I think, but not sure on pulleys. This is currently a non oem ac car, so have non ac pulleys.
The stock set up has an idler pulley for the water pump when you have A/C. The Bouchelon double pulley solves that issue nicely by driving the power steering pump and water pump with the same belt, eliminating the idler.
The A/C and alternator are driven by a double belt from the 4 groove crank pulley. It looks like you have the right double alternator pulley. I believe the alternator bracket is the same, but I'm not 100% sure about that. I think I have the bracket too if you need it.
The ports need to point up on the compressor. I don't think they will clear the distributor if laid on their side.
I'll walk out to the garage and take some pics in a couple minutes.
