BillGrissom
I have owned a 65 Newport since 1991. Originally a southern CA car, I had it 7 yrs in Atlanta (parked outside under oaks) but now back in CA. It still has minimal rust. I treated surface rust on inside of doors at top (factory barely painted) and also at the bottom corners where moisture collects and in the bottom qtr panels. Do so before you get rust-thrus. I like the body style w/ the vestigial tail fins, and it complements my 65 Dart. Unlikely to ever be worth much since a C-body and a 4 door. A guy in Lodi neaby has advertised a 66(?) C-body on craigslist for years ("desperate"), asking ~$3500 and was trying to sell as a package deal with an early-A "toad" car (~1962). It would be better to fly to CA/AZ/NV/NM to buy a rust-free car and drive back to Detroit than spend years welding in rust repairs. Make it a SoCal vacation trip.
It is easy to get performance parts for the engine and transmission since common w/ popular A/B/E bodies. 1965 started the common sliding-yoke drive-train, instead of ball & trunion front U-joint, though the transmission was still cable-shift so 1yr-only tranny. But, one could bolt-up a later lever-shift tranny and Lokar makes shift solutions. Later years added clumsy emissions controls. Parts are not available, but where I live you don't need to keep that. Indeed, you can bolt on throttle-body fuel injection (EFI Tech ~$1000 or used Holley Commander 950 <$600 ebay) w/ O2 sensor. For sure change to electronic ignition since cheap and easy (see www.megasquirt.com). Pertronix Ignitor II or III is simplest and works well or retrofit GM HEI 8-pin for cheap and strong. As mentioned, body parts are tough. A deer crunched my passenger door 10 yrs ago and I had to get a replacement from AZ. But, insurance totaled the car and I paid only $150 for the door and painted myself so came out way ahead though I didn't need another project.
Many parts are cheap, much less than years ago when you had to go to the dealer. But, you must be resourceful, wait, and search ebay and craigslist periodically. Ex., I lucked on a brake booster w/ MC for $70 on rockauto a few years ago, then sold the MC locally (switched to a 2-reservoir type). I buy common parts cheap on clearance. I got a master tranny rebuild kit for $50. Re the elusive $600 ball & trunion joint, I have one w/ driveshaft sitting in my garage. It is the larger one (~4"D) that I recall fits 1964- C-bodies. I didn't even have to pull it, since sitting inside a 64 Belvedere at PickNPull. Thought I might retrofit for my 65 Dart (uses smaller joint ~3.75"D) but I now have 2 full rebuild kits for that. Re info, the A-body site is better for engine, tranny, brake & electrical questions and most interchanges. Suspension is the same design, just all parts are larger.
