celticwarlock
I didn't know where else to post this, so I'm putting it here.
I have a '00 Dodge 3500 van that I'm having a potentially serious issue with. I was coming down a hill today and had to hit the brakes firmly. When I did, I heard a noise like something in the steering/suspension shifted, and the caster went out of adjustment on the left front wheel.
At first, I thought the upper control arm shifted because one of the bolts was a bit loose, so I had it aligned. The tech said he had to max out the (+) caster adjustment to get it in spec. All was well until later in the day, when the same thing happened. The front end is in otherwise good shape....there is no play, it has quality parts that aren't too old (I rebuilt the entire system a couple of years ago), nothing is loose or worn, nothing is broken or bent, all the frame welds are fine, etc. I cannot find ANYTHING wrong with it (visually). Even the strut rods appear fine. The toe and camber setting look okay when the wheel is straight and I look at the relationship each tire has with each other, and with the street (I know it only takes a subtle adjustment issue to throw things out of whack, but for what it's worth, nothing is obviously amiss).
I have braked firmly a few times since to see if it worsens, and it hasn't, nor has there been any more noise. The front end feels as tight as it should despite this problem, but it is pulling very hard to the left.
What the hell is going on with this van? I need this thing to make a living, so this is really important. Any help anyone here can offer would be greatly appreciated. I have done LOTS of front end work on MANY different makes and models over the years, and this has me totally stumped.
