swisherred
67 newport
My signals have been fine since I replaced the turn signal switch. Been good for 6 months. Last week I noticed that they had stopped working. My brake lights had stopped also. I fixed the brake lights...loose connector in the left kick panel, but I still havent found the issue with the signals. The flasher clicks ON but not back and forth. It clicks OFF when I turn off the signals. The hazzards work as long as the brake pedal isnt depressed....I think they cancel each other out when you hit the brakes. My bulbs are new, the sockets were cleaned and greased....at the same time I noticed that my trunk light wont turn off...had to remove the bulb. even if I unplug the trunk switch...the light is still on. Could this be related?
I have the FSM and just dont see anything that could cause this.
